how to create timed while loop with period in terms of ticks
Hi, I am unable to find the timed while loop with period in ticks in the control palette. Please help me in finding, or is there any change in properties in timed loop to change the period from ms to ticks.
(1,104 Views)
Accepted by topic author msabah38
Hi msabah,
different timing sources than "ms" are only supported on dedicated targets for your code, like cRIO or FPGA.
On plain Windows the TimedWhileLoop most often is overkill and seldomly improves your code!
That being said the answer to your question is quite simple:
Wire the DAQmx sample clock to the clock name input of the TWL - as is shown in the example loop above yours!
(1,102 Views)
