how to customize the fifo in sbrio 9642
i am using sbRIO 9642 for controlling the speed of the fan on sound and vibration signal simulator against vibrations
i want to use FIFO  buffer in order to collect those data poitns
how can i customize the fifo
below are the snapshots of the pop up windows...
(3,018 Views)
What do you want to do exacty with this FIFO ? What is the general architecture of your application ? Do you need to use a DMA FIFO to transfer data from FPGA to Host (RT code) ? Or is it just a FIFO to transfer data inside FPGA code ?
What are the specifications about the input signal ? (range, precision)
(2,985 Views)
i am acquiring the vibrations from a analog channel of sbrio and and want to perform FFT of that signal so thats why i wanted to use FIFO
i am using FIFO to transfer data inside FPGA code
input signal is of 2.4567.... voltage signal
the integer part is constant. only decimal units are varying and my precision is "6" digits
(2,976 Views)
About your FIFO configuration :
1) For "general" tab information, you can leave the default parameters (as shown in your snapshot). You probably do not need a 1024 element FIFO (most of time it's not useful using a "deep" FIFO, a few elements can be enough). If you really want to optimize the use of resources (especially the memory used for FIFO implementation in your case), we need to have a look at your code.
2) For "data type" tab information, this configuration should be OK : FXP < + 22 , 2 >
As you can see below, it is OK with the specification you gave to me (range and precision).
(2,965 Views)
I think this lien can help you http://www.ni.com/white-paper/11198/en/
(2,835 Views)
