how to customize the slider
I am simulating a moving box on a straight path. So basically I want to show where the box is when time goes by. I think I can use "horizontal slide"  but I need to customize the slider so that it shows the real size of my box. How can I do it? or is there other way to do this kind of simulations?
Joyce
(4,633 Views)
Accepted by topic author Joycezh
Do you want something like this? You could also do this with a picture and move the picture around on your user interface so that you could creat more than one box and have them be different sizes.
Tim
GHSP
(4,623 Views)
Hi Joyce!
There are plenty of ways to customise the slider for your needs.  If you hover over certain parts of the control you can use the drag handles to edit:
Additionally you have much greater flexibility by creating a custom control, which you can access in the following manner
Peter D
(4,621 Views)
Thanks!
(4,603 Views)
Thank you!
great to know this trick!
(4,600 Views)
Just for fun!  Here's an example using a picture control.
Unzip the file, run the VI and move the slider.
Peter D
(4,594 Views)
