how to delet block diagram
Dear Sir,
Please help , how to permanentaly delet block diagram of the programme, so it will protected and show only front panel and no one can see the code of the programme.
please tell me steps or any example of deleting it.
Message 1 of 8
(3,991 Views)
Accepted by topic author Julian_prince
A better option is to password protect the VI.
What are you trying to hide?  Unless you are using some proprietary patented algorithms, it is usually more beneficial to have the diagram visible. This way others can find bugs and improve it. 😄
To save VIs without diagram, you can create a source distribution with special option. It is all explained here.
Are you trying to distribute a program? In this case you can build it into a standalone executable that does not need LabVIEW installed.
Message 2 of 8
(3,983 Views)
Once you removed block diagram you cant recovered it back so take a backup before doing this.
One more thing instead of deleting the VI why cant you use password protection?
This better then deleting.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 3 of 8
(3,976 Views)
--Ranjeet
Message 4 of 8
(3,976 Views)
Please tell me the steps to delet block diagram, because deleting block diagram is best option for me.
Message 5 of 8
(3,953 Views)
Did you follow my links above? They also contain a lot of information why you think had before deciding to do it. 😄
Message 6 of 8
(3,949 Views)
If you have difficulties in following the link then here it is.
Make sure of these and remember
1. You can no longer make any editing changes or view the block diagram.
2. You cannot open or run the VI on any other version of LabVIEW, older or newer.
3.You cannot open or run the VI on any other OS.
One more thing, once it deleted then you will never able to recover it back so I sugges you to take a backup.
--Ranjeet
Message 7 of 8
(3,938 Views)
  1. Make a backup
  2. Open the Block Diagram
  3. Press Ctrl-A to select everything
  4. Press Delete
  5. Curse the internet pranksters
Jim
Message 8 of 8
(3,924 Views)
