07-20-2006 04:46 PM
07-21-2006
03:55 PM
- last edited on
04-03-2026
06:10 PM
by
Content Cleaner
Jeff,
So you would like to use a Windows XP computer for the user interface? The easiest method to add your VIs to this panel PC would be to create an EXE of the program and then deploy that to the PC. If you don't have LabVIEW installed (which sounds likely) you will need to install the LabVIEW Run-Time Engine as well, which you could easily do by creating an Installer for the program. To do all of this you would just have to leave the VI and Library targeted to My Computer and then create an Application and Installer for your VI. Be sure to take a look at this KB just to make sure that you include the correct support files for your Shared Variables.
Please let me know if you have any other questions. Thanks!
Andy F.
