how to design a main menu?
Off-topic: Mathan, your images don't show up. I've actually seen this in some of your other posts in other threads as well. Are you posting these images from your gallery, and then cleaning out your gallery? If so, that deletes the image(s) from the NI servers and leaves you with a "no image" icon. I personally think that Lithium's implementation of this gallery is brain-dead because of this, so I always try to upload images by attaching them to the post.
Message 11 of 15
(826 Views)
smercurio_fc wrote:
Off-topic: I always try to upload images by attaching them to the post.
Ahhh sorry.....
Off-topic: Hereafter ill try what you suggested. Thanks
Message 12 of 15
(799 Views)
@muks: thx for your example VIs. for now it works that way, but i will try this "run-time-menu"-thing.
and also thx the others for there suggenstions and hints!
Message 13 of 15
(793 Views)
Hi fr33k,
maybe this helps:
http://decibel.ni.com/content/docs/DOC-3771
Mike
Message 14 of 15
(789 Views)
Mathan wrote:
Ahhh sorry.....
No need to apologize. You weren't doing anything wrong. There's no issue with using the Image Gallery, as long as you don't clear it out. If you do, all of the image links you've posted are now defunct. This is an issue with the forum software and the apparently brain-dead folks over at Lithium, not you.
Message 15 of 15
(772 Views)
