how to detect the position of window?
I have two questions please .
1) How i can to detect the last position of the window of my application in labview?
2) If I succeeded to detect this position of the window, And i saved it in the "INI" file, how I can apply this position values to move automatically my window of the application in the first start-up in labview ?
Thank you for your help.
(3,771 Views)
Accepted by topic author imadouino
Hi imadouino,
you can use a property node to read the window postion.
When you want to set the window position you use the very same property, but switch the node from "read" to "write" mode…
(3,762 Views)
to get you started, bc i found it hard to find the properties when i started.
hope that helps
<edit> to change the properties from read to write, right-click on the property and set to "Change to Write"</edit>
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,743 Views)
thank youuuuuuuuuuuu it worked 😄 😄 Smiley Very Happy
(3,734 Views)
