how to detect window close event and do some task before exiting
Hi
Anyone knows how to detect window close event and do some task before exiting ?
Sridhar
(6,138 Views)
Accepted by topic author sridar.m
Use Event structure to detect window close event. In event structure,
Select This VI -> Panel close event for this task. See attached picture.
(6,131 Views)
Thank you Mr Kumar B
I have tested it with "Panel Close ?" event. It works but I cannot discard it.
Let me know how to discard the same event.
And will it work with executables ? Can i discard the same event to prevent it from exiting?
sridhar
(6,095 Views)
Yes .You can discard the panel close event by passing "TRUE" boolean value to the "discard ?" terminal which is lied in the right side of that panel close(filter) event.& It will work in executables.  See attached picture.
(6,083 Views)
