how to determine allowed names?
Using Labview and an IVI-COM driver to talk to an oscilloscope. How can I determine the allowed names that I can use?
(2,570 Views)
You should have received this information from the vendor that sold you the IVI-COM driver.
You might also consider using a native LabVIEW driver for your scope. If NI has one, I think it will be easier to use. Look at ni.com/idnet to see the available drivers.
Brian
(2,570 Views)
