how to develop simple time based ramp driver for lab view VI
how do I develop simple time based ramp driver for lab view VI
(3,404 Views)
Could you please elaborate on your question. What is the nature and purpose of this ramp. Does this output a voltage from x to y over time based on n samples?
There is already a ramp VI in LabVIEW (depending on the version you have) that you can configure to do what I described above.
(3,404 Views)
TRY THIS RAMP AND SOAK VI
(3,404 Views)
Here it is converted to LabVIEW 2010.  However it is missing the AO and AI read and write vis since I don't have that package.
(2,908 Views)
Perhaps someone can explain the use of the shift registers?
(2,903 Views)
To open this up to a wider audience, here it is saved as LabVIEW version 8
(2,898 Views)
