how to disable(inverse) icon of ui , coding a ui for production / engineering mode
Excuse me
I coding a sample UI on LabView8.2
full function be enable at ui , and engineer can adjust program factors through ui
now , i want to categorize production/engineering mode for the ui
engineer mode - enable full function for engineer adjust
production mode - only enable a little function for operator adjust
I don't hope to coding 2ea program , I hope use sample process to achieve it
so ....
I want to builld a ui for production mode
Have Labview disable(inverse) technic??, let icon convert "gray" --->disable the function
user can see the icon on ui , but they can't adjust the function factors
thanks
(2,778 Views)
I'm sure there is a question you want to ask but not sure what it exactly is.
To disable a front panel control, right click on the terminal and select Create>Property Node>Disabled. Right clcik on the property node and select 'Change to Write'. Wire the constant you want to the input. The context help explains the values and what each does.
(2,771 Views)
Accepted by topic author stockton
" 2ea program"
"disable(inverse) technic??" , let icon convert "gray" --->disable the function
I don't know what some of the terminology is that you are using.  Or what you mean by disabling icons or functions.
I am going to guess that you actually want to be able to disable and grey out controls on the front panel.  You can write to a property node for each of your front panel controls called "disabled".  You can enable, disable, and disable/grey.
Message Edited by Ravens Fan on 03-28-2010 09:52 PM
(2,767 Views)
