how to dispaly x and y value on front panel
Just stuck to display values of x and y (coordinates) on the front panel.
1- Start from (0,0) to (300,0) with x value difference of 50 should be incremented each time.
2- then after reaching first condition is should be like (0,50) to (300,50) and then (0,100) to (300,100)
please help to do this.
(1,701 Views)
What have you tried? Once you know the set of points, just display them in an xy graph.
If you only want to show a singe point that moves to the various points with time, make sure to use a plot that has points, not just lines.
(1,678 Views)
Somethings like this?
(1,667 Views)
