how to display a string in menu ring indicator
Veeru,
What you asked for does not make much sense. With a menu ring, you can only have a single selection. And, with your code, you do not get the text of the menu ring, only a numeric. Do you look at the answer that shows how to use the RingText.Text property?
Message 11 of 26
(1,398 Views)
Thanks All
Message 12 of 26
(1,384 Views)
Sorry i made a mistake in my question.
Foe ex if the ring control has options A,B,C,D and  if i have selected any of those options i need an indicator to display all the selections i have made.Is it possible to do.
Message 13 of 26
(1,381 Views)
MikeS81 wrote:
To add some strings to an enum you can use a property node.
Mike
Hi Mike,
Enums CANNOT be updated during run-time using property nodes. Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 14 of 26
(1,373 Views)
See the attached VI. Smiley Happy
Message 15 of 26
(1,368 Views)
If you still want even the unchanged selections of the ring, then you have to use its Mouse Down event.
Message 16 of 26
(1,366 Views)
Thanks partha
The attached vi is not working
Message 17 of 26
(1,363 Views)
Hi Veeru,
It IS working for wh tyou have stated here. Smiley Happy
Else, what is your exact requirement? Smiley Surprised
Message 18 of 26
(1,359 Views)
Thanks very much partha
I think still i haven't cleared what i am trying to do.
From the ex, for ex if we select all the options in sequence, i need to display the selections line by line(without changing the index in array we need to see all the options selected line by line).If i am not expalined clearly let me know.
Message 19 of 26
(1,355 Views)
Your explanation is totally unclear! Smiley Indifferent
Message 20 of 26
(1,350 Views)
