how to display array values on indicators
P.S. The image from jcarmody is a snippet. You can save this to your hard drive and then drag it to an empty block diagram. Did you do this? Did it work? If it does work, then there is a difference between the string you are getting and what you originally said you were getting.
Message 11 of 41
(3,042 Views)
added an indicator to output of visa
Message 12 of 41
(3,036 Views)
Your bye count is zero. I guess I should have said arbitrary high to be clear. The Is Connected property does nothing. Remove it.
Message 13 of 41
(3,028 Views)
You are reading 0 bytes.   So what kind of response do you expect from that?
Message 14 of 41
(3,026 Views)
It's also a waste to create an indicator and then not have it visible on the block diagram.
Perhaps you should stop and take s couple of the free tutorials.
Message 15 of 41
(3,020 Views)
Never mind about the indicator. Just saw it nestled on with the others.
Message 16 of 41
(3,010 Views)
I see the message was edited and another image added, but a completely different block diagram.  So now I have no idea what the problem is, which diagram is related to the problem, and what we are supposed to be responding to.
Message 17 of 41
(3,006 Views)
read buffer reading all these values but still error at string input not in expected format
Message 18 of 41
(3,002 Views)
Now I can't see the block diagram to know which of your versions of your VI that front panel is related to.
Message 19 of 41
(2,998 Views)
But with \ Codes, you can see the mismatch. Get rid of the null character.
Message 20 of 41
(2,995 Views)
