how to display sub-vi front-panel within a tab-control
sub-vi cannot be modal.
each tab will display the front panel from a seperate subvi - the idea was to break apart a large unmanageable vi into smaller subvi's.
The examples on the NI web site have all the controls within one VI.
Perhaps the solution to this problem exceeds the capabilities of Labview.
(2,615 Views)
If I understand the problem, you could use VI server to start a different VI from each tab.
(2,615 Views)
