how to display the message received by the arduino in labview
can anyone please help me how to display the message received by the arduino through GSM in the LabVIEW front panel
(3,529 Views)
Use serial port. Only you need to redirect output from GSM to serial.
Share more details
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,509 Views)
i want to display the value of pH in labVIEW which is sent to  arduino  through GSM from the pH sensor which is at remote location.can it be done with arduino
(3,494 Views)
It's a little unclear about your connections. Is the gsm between the arduino and sensor or between the arduino and the pc with LabVIEW?
(3,474 Views)
All I want to say is if you can receive the value in arduino then for displaying the serial port is only through serial monitor in PC. for displaying using labview read the value using VISA which is send through arduino to serial.
Serial.print() which will disply the value to serial port. For checking in same PC use serial monitor and for other pc use visa read in labview
--Ranjeet
(3,432 Views)
GSM is in between arduino and pH sensor.micro controller which is at other side takes the value of pH value from the sensor and it sends to arduino through GSM.
(3,423 Views)
