how to display the real time data
I use NI usb6009 to acquire 4 channels data, i want to display the waveform and the real time data at the same time. So i use Analog 1D wfm Nsamp Nchan function to read data from USB 6009. I connect the data terminal to a waveform chart. How can i get the data from the data terminal to display them in a number controller?
Thanks for your help or advise.
(2,323 Views)
Hi 青风细雨楼,
use the "Get Waveform Components" function to get an array of your values. To work on this you can use the array functions to get specified array values.
Mike
(2,320 Views)
