how to display time in graph, using time string format
i have set of arrays string format as a date and time with data...........
how to display on the graph data with time?...
how to do this conversion?
Balaji DP
(3,309 Views)
Here you go:
Norbert
Message Edited by Norbert B on 09-11-2008 07:42 AM
Norbert
Expert: Geometry
(3,296 Views)
this is working with 8.5  but i have to develop this for 7.1... but in 7.1 there is no option for this task......
how to do this in 7.1?
Balaji DP
(3,276 Views)
Well, it seems that the format string indeed does not work with LV 7.x.
So if you really need the time/date as a timestamp datatype, you have to either
a) upgrade LV (easy solution)
b) calculate the time in seconds regarding the time/date string. This is quite elaborate and may be limited to certain time settings in the system... but it should be a valid workaround.
Sorry for not being more helpful here....
Norbert
Norbert
Expert: Geometry
(3,267 Views)
