how to display wiring connectivity of two connectors using lab view
hello everyone!
am using Lab View 7.1 (Professional). Is this possible to show the wiring connectivity of a cable on the front panel of LV. for instance i have the wiring details in text form and i want to Display it on LV, i mean a graphical representaion of the connections. if this is possible then how can i achieve it.
i really cant understand if this ispossible, can anyone please help me.
thanks
(3,288 Views)
If I understand you correctly,
you want to illustrate a cable  on your front screen  and determine if the  wiring is OK.
A suggestion would be to import the cable wirng as a picture, with enable buttons(transparent) underneath so that as you moved across picture  you could enable
appropiate buttons to determine status.
Regards
xseadog
(3,268 Views)
thanks for the reply.
yah u got me right, thats what i intend to do. but let me make it more clear that i want my program to read from a text file for the connections (that is which pin of one connector is connected to which pin of the other connector) and displays the connections graphically.
i have attached a pictorial representation of the way i want the wiring diagram to be represented as.the program loads different files at run time, there it should determine at run time how to represent changes in the diagram therefore i cant import one picture here.
i hope someone could help me in resolving this problem.
thanks in advance.
(3,247 Views)
m sorry but m unable to attache a picture. the message fails to be sent.
neway i hope you understand wht am tryin to say. i wud really appreciate some help in this regard.
(3,247 Views)
What type of picture did you try to attach. The forum doesn't permit .bmp files. If that's what you have, save it as a .jpg or .png.
(3,233 Views)
I suspect Dennis is correct re:why you can not post your image.
Lacking that I'll suggest you look at using a picture control that you first populate with a static image. After that draw some lines to do the connections you are after depending on your script.
This thread
http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=14&jump=true
contains a lot of examples that use the picture control. NONE of those examples will do exactly what you want but they may be worth looking at.
Ben
PS Dennis, Will I have an oppertunity to hear your voice tomorow?
Message Edited by Ben on 03-15-2006 11:48 AM
(3,220 Views)
Hi Ben,
Yeah, you'll hear me tomorrow. It might be an angry voice though. My budget request (for the 4th year in a row), to upgrade me and all of the other users to the latest version of LabVIEW and TestStand has been turned down.Smiley Sad
Dennis
(3,207 Views)
