how to distinguish between network drive and local drive
Hi I have a File Dialog, and i'm looking for a way to determine drive type, network or local. Currently i'm using the stupid - Path to string->what is the first letter->is it C or D - way. thanx
(2,840 Views)
Accepted by topic author sebastiant
I do not think there is an LabView function, that does this. You will have to call a Kernell32 function.
Function
Here is the code. It worked for me. LV2010sp1 win7 32b.
The example is saved as 8.0 vi
(2,829 Views)
that did the trick thanx!
(2,812 Views)
If you are about to use that function call in some serious program, please proceed some testing before. I assembled the calling parameters via trial@error technique.
(2,806 Views)
