how to do analog input and output on PDA (Pocket PC) at the same time?
Hi, I am trying to send a continous signal out and read the response at the same time...I was wondering if anyone has done this before. I get either 200284 or 200278 all the time! (PCMCIA 6062E)-Pocket PC, Labview 7.1. DAC0OUT (AO) and AICH0.
(3,791 Views)
I understand that you are doing analog input and output on a Pocket PC PDA in LabVIEW 7.1 with a PCMCIA-6062E. There's an example program available on our website that does analog input and output using the same hardware and software that you are using. You can find the example at
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=CB8058B9797C16C8E034080020E74861&p_node=%20200515&p_source=External
I recommend trying this example program. If you continue to get the error, the following knowledge base document should at least give you an idea of why the errors occur.
http://digital.ni.com/public.nsf/websearch/001DA4DB6A31CF8886256D33006FA857?OpenDocument
Let us know if trying these suggestions doesn't resolve the issue. Thanks for contacting
NI.
Marcus G.
(3,791 Views)
Thank you Marcus,
I am aware of both links...I was wondering if i can get the actual VI of the program rather than *.exe so i can insert it in my main VI.
Thank you again
Wafa
(3,791 Views)
Hi Wafa,
I've tried to get the source code to the example, but since it is saved as an executable, I am unable to extract the source code. I am trying to contact the author of the example program in order to obtain the source code from him. I will post the source code if I am able to get it.
In the mean time, did the knowledge base document help you resolve the errors you were receiving in your data acquisition? If not, please let us know and we'll further assist you in troubleshooting the issue.
Marcus G.
(3,791 Views)
