how to do like this with array?
How to do like this with array?
I have 2 constants array put in main while loop ( array1{6,6}; array2{4,4} ). Those arrays will be come the input data for st in the small while loop inside.
The input data look like : [6,6],[4,4],[6,6],[4,4]...... I have to put input data to result array[8]. The method is:
input data result data
[6,6] --------------------------------------------> [6,6,0,0,0,0,0,0]
[4,4] --------------------------------------------> [6,6,4,4,0,0,0,0] ( this period, just add each element in new array)
[6,6] --------------------------------------------> [6,6,4,4,6,6,0,0]
[4,4] --------------------------------------------> [6,6,4,4,6,6,4,4]
[6,6,4,4,6,6,4,4] ( 1st period )
When the las index of result data array is filled in, I have to collapse the result data array to be this array:
----------> collapse: [6,4,6,4,0,0,0,0] ( take the average of 2 continuous element add to new result data array)
Next input data
[6,6] --------------------------------------------> [6,4,6,4,6,0,0,0]
[4,4] --------------------------------------------> [6,4,6,4,6,4,0,0] ( this period, add the average of 2 continuous elements in new array )
[6,6] --------------------------------------------> [6,4,6,4,6,4,6,0]
[4,4] --------------------------------------------> [6,4,6,4,6,4,6,4]
[6,4,6,4,6,4,6,4] ( 2 nd period)
----------> 2nd collapse [5,5,5,5,0,0,0,0] ( take the average of 2 continous element add to new result data array)
Next input data
[6,6] ....wait until input data has 4 elements
[4,4] -------------------------------------------------------------------------------------> [5,5,5,5,5,0,0,0]
[4,4] -------------------------------------------------------------------------------------> [5,5,5,5,5,5,0,0]
[4,4] -------------------------------------------------------------------------------------> [5,5,5,5,5,5,5,0]
[4,4] -------------------------------------------------------------------------------------> [5,5,5,5,5,5,5,5]
[5,5,5,5,5,5,5,5] ( third period )
----------> 3rd collapse [5,5,5,5,0,0,0,0]
This wayl to make the tren graph.I  made  an VI to do that , but it's not yet correct.
(3,896 Views)
Frankly, I don't understand your problem description or your VI.
In the description, the output array has a fixed size of 8 elements, is this correct? In this case you should initialize an array of 8 elements and do all operations "in place". I don't udnerstand the purpose of all the other code.
There are a lof of things that don't make any sense at all.
  • The second largest loop has no purpose, because it iterates only once per call
  • Sometimes you are concatenating an empty array to an existing array. This makes no difference.
  • Why is some of your data EXT representation???
  • What's up with complicated constructs such as that small loop shown in the picture. I show a somewhat simpler alternative.
Anyway, I have a hard time understanding your description. What should happen at the end? Do you have a link to a website that describes the algorithm? Does the algorithm have a name?
Message Edited by altenbach on 01-10-2008 09:55 AM
(3,861 Views)
Hi altenbach ,
Thanks for your advice, i fixed it and tried some thing, it works!  Thanks alot for ur help!
(3,821 Views)
For understanding: the thread is related to this one!
(3,817 Views)
