how to do run time to my program?
Hi guys.
I have finisihed to programmimg my program, so i want do run time to my program to be indepentent program of labview.
please give me all steps from A to Z and with details.
Best regards.
(2,908 Views)
You need to create HEX and installer file.
here
http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/build_installer
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019N8tSAE&l=en-US
Google it. you may get better answer !!!
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,907 Views)
Actually, you need to create an EXE with the application builder first and then you can create the installer.
If you have the app builder, directions are in the help.
(2,871 Views)
Here are the instructions to build a standalone program.
The target system also needs to have the correct LabVIEW runtime engine installed. It can be installed seperately or included with the installer that you create for the executable.
(Note that you need LabVIEW professional or add the application builder. For example LabVIEW base, full, or the student version does not have this functionality.)
(2,823 Views)
