how to do the vector operations as simple as in Matlab
Hello All
I use quite much the operations like e.g.:
a=[1 -3 4];
b=a(find(a>0));
In LabVIEW I need to make a for loop with shift registers, for every element verify the condition, if true insert the element to the vector, etc. etc.
It is so easy in Matlab, is there a very simple way to do it in LV. Maybe there is some vi which I have not noticed.
Thanks in advance.
Pawel
(2,676 Views)
Pawel,
I use the "Conditional Auto-Indexing Tunnel.vi", which is part of the OpenG Toolkit "array" library available from OpenG.org.
Attached is an example.
-Jim
(2,676 Views)
This is so beatiful.
Thank you very much.
regards
Pawel
(2,676 Views)
