how to down load and using OpenStreetMap offline with LabVIEW 2013
Dear All
How can i download the OpenStreetMap  database and API for LabVIEW to call this offline map database !
Luong.Tran
(5,641 Views)
Hello QuangLuong.Tran,
I am not entirely sure what you are asking for. If you are simply interested in obtaining the OpenStreetMap API it apears the API can be obtained from the following link.
http://api06.dev.openstreetmap.org/
(5,597 Views)
Hi Hockeyjim07
I mean how can i use OpenStreetMap with offline mode. base on your link  it is required the computer have to access internet.  so my question is how can i download the OpenStreetMap database(pictures) and setup to offline mode and using OSM api to call the offline map?
Luong.Tran
(5,587 Views)
the best guess I can give you is that you would have to run your own server for OSM, perhaps on the target machine, in order to do this but I am not sure what I can do for you from a National Instruments perspective.
(5,557 Views)
Accepted by topic author Luong.Tran
Thanks!
(5,541 Views)
