how to download labview 2010?
A link to "download LabVIEW 2010 for Windows immediately" seems to be broken (http://digital.ni.com/src.nsf/websearch/D5F33DFEF6E349628625776C006A8E40?OpenDocument&node=node=203014_us); it displays " Services Resource Center Error HTTP Web Server: Lotus Notes Exception - Entry not found in index"
Which link can I use instead?
E
(14,016 Views)
How did you get to that link?
Assuming your SSP is up to date and you have access to the SRC, you can get LV 2010 from here:
https://www.ni.com/en/support/downloads/software-products/download.labview.html#359446
and LV2010 SP1 from here:
https://www.ni.com/en/support/downloads/software-products/download.labview.html#306275
You can always find what is available by going to ni.com/src.
(14,007 Views)
nevermind
(14,002 Views)
Thanks, but again, the link in there seems to be broken: Download LabVIEW 2010 Modules
(http://digital.ni.com/src.nsf/title/FB76DB328E265F9D8625776C006573C6?OpenDocument )
E
(13,965 Views)
I can finally see where you are getting these links.  It appears the crosslinks are bad.  If you follow the links from the src main page to get to the items, it works.
LV2010 modules:
LV 2010 SP1 modules:
(13,958 Views)
