how to draw a box in a screen
Hello all
I have a program which show the image from a webcam and I need to add a coordinate system  with the origin in the center of the image, and also a box concentric with the coordinate system. Following some examples  I could add the  coordinate system as a grid of one horizontal and one vertical lines; I know that I can draw boxes using the indicator palette (as shown in the attached picture) but I need to do it programatically so I can  adjust the size of the box and also its orientation. Apparently it could be done using property nodes but I did get a way to do it.  Any suggestion is welcome. Thanks
(3,419 Views)
You can use the  Overlays a region of interest (ROI) vi found in NI-IMAQ to draw rectangle on the image .The IMAQ Select Rectangle.VI also allows the user to select a rotated rectangular area.
(3,386 Views)
