how to draw a line connecting two points on XY graph
I have three data points plotted on a XY graph from three separate arrays.  I am trying to draw a line to connect two points: 1) reference point (0,0) and 2) random number (0,Y).
When I use draw.line, the start point is from the top left corner or starts in the middle and moves to the left side.
On the screen shot .jpeg, I want to connect the yellow and red points.
Any help would be great.
Thanks 🙂
(8,444 Views)
here's the attachments
(8,443 Views)
For the graph properties, look at the plots tab.  If you look at plot 2, you have a line type that does not directly go from point 1 to point 2.
Plot 3 does have the direct line type.
(Plots 0 and 1 have no line connecting points.)
(8,422 Views)
Start with a "move pen" then use a "draw line".
You don't need the "plot images" overlay for this. Simply add a second point to the plots as needed and set a plot style with interpolation.
See attached quick draft, LabVIEW 9. You can change the line color if desired.
(Your entire VI is way too big and can be simplified dramatically. Use a state machine architecture and subVIs. Also learn about mechanical action settings. For example "save data" and "clear data" should be latch action, eliminating the sequnece structure and property node in their frame 2.. etc. etc.)
(8,414 Views)
