how to draw phasor diagram of different electrical parameters
i am new to labview
i am doing data acquisition program,and for further analysis i want to know
how to draw phasor diagram of current ,voltage etc.
(7,913 Views)
I apologize, but I am no expert on phasor diagrams. It turns out that it's relatively difficult to draw a phasor graph using LabVIEW, but I've written an example that (hopefully) will help you get started. The example accepts an input for Voltage magnitude, current magnitude, and the phase between them. It then draws something resembling a phasor diagram.
There are some optional settings you can make for the graph, such as plot colors, axis settings, etc.
Hope this helps! The example was written for LabVIEW 7.1. The main VI is called Phasor Diagram Example.vi.
Message Edited by Jarrod S. on 02-23-2006 05:46 PM
Jarrod S.
(7,894 Views)
thanks jarrod for your reply .it is working and hope i will get useful suggestions from you in future
mukesh kumar sahu
vellre institute of technology,vellore
tn,india
(7,865 Views)
that is beautiful, thanks. 🙂
(4,372 Views)
