For the project of my senior year I have to drive 2 3-phased motors (2,5 kW and 3,7kW) and two steppermotors with Labview. But i'm not very familar with the program and I need some help.
The two steppermotors are needed to drive a XY-table. I think the two steppermotors can be driven with the "2-Axis Stepper Motor Controller (PCI-7332)". Do I also need to buy the "Motion Assistant SW for Motion Control Programming" for programming the movement of this table, or could this be done with the program Labview itself? The current steppermotors(STEBON) for the XY-table are driven by a DIGIPLAN-drive. But since I can't fin anything on the net about STEBON-motors or DIGIPLAN-drives, I'm thinking about stepping over to the PCI-7332.
The second problem is that I can't find anything about how to drive the 3-phased motors. I guess I need an interface and a frequency inverter, but I'm not sure which frequency inverter is compatible whith Labview, or does this has to do with the choise of the interface? And if I have the interface + freq. inverter, do I need an extra Labview add-on for controlling these motors.
Many thanks,
Raf.
