how to dynamically change selection mode of listbox?
Hello everyone
Is it possible to change the selection mode of listbox dynamically?
Both cases in the attached vi functions similarly. I want the listbox to be changed to 1 item selection mode when the string selected from combo box is SET.
Can anyone help please?
sarkar
(3,464 Views)
You can change the selection mode of a listbox using a Property Node.
(3,461 Views)
Accepted by topic author chips
There is a property node for Listboxes called Selection Mode.
Don't use the terminal of the control in one case and a local variable of it in the other.  Move the terminal outside the case structure and wire it into the case structure.
(3,460 Views)
Thanks a tonn you guys. It was really helpful 🙂
(3,451 Views)
