how to edit a Vi so you could add an input to it?
i got it. thanks
Also, I'm using a DAQ Assitant that has 4 channels from. Do you happen to know how to choose which channel to output from the DAQ data because each channel has to be connected separately to stuff.
Message 11 of 14
(669 Views)
Use the split signals function in the Express, Signal Manipulation palette.  The block icon can be expanded up or down to have has many outputs as you need.  I believe the order of the outputs is directly related to how you defined the channel order in the DAQ assistant.
Message 12 of 14
(666 Views)
There is also a Select Signals Express VI if you really want to stick with Express VIs.
Message 13 of 14
(648 Views)
Message 14 of 14
(595 Views)
