how to edit columns in a saved spreadsheet
hey, i made some changes in the code, can you see if this looks right.
thanks
Message 21 of 44
(1,277 Views)
As far as I can tell, you haven't done anything. You haven't cleaned up the wiring or put the VI I sent you, in your program as a subVI.
Here is your VI back with one of the signals modified. You will have to specify the actual column name you want and then repeat for the other signals.
This is really basic stuff - adding a subVI. You should probably look at the training resources available at http://www.ni.com/academic/lv_training/how_learn_lv.htm
Message 22 of 44
(1,277 Views)
hey,
thank you so much for helping me. the code is working perfectly fine and the excel file has the headers with the names i wanted them to have. I just have one more problem with the code. i want to make some calculations with the data which is being saved in the excel file and i want labview to make these calculations so that everytime i run the code the saved excel file has the data and these calculations.
thanks
Message 23 of 44
(1,271 Views)
What is the problem with making calculations? You are already making several calculations in the program. Just make a few more.Smiley Wink
Message 24 of 44
(1,267 Views)
yea i m sorry, i dont know what i was thinking that time. could you please help me out with this: like you know how in the write to measurement file you can choose the vi to  'ask the user only once'  to select  the file  he wants  to save in.  the  problem  is that  when  the  vi  asks  the  user  to  which  file  it  wants  to  save  the data, it asks it after the instrument the computer is connected to has started running. i want it to first ask which file it wants to save the data in and then start running the program.
Message 25 of 44
(1,244 Views)
For a file dialog, How about the File Dialog function? Smiley Wink Just put it outside the main loop and wire the path in.
Message 26 of 44
(1,240 Views)
i m trying to wire the file dialog in the code. but it is giving me errors. i m so sorry, can you please show me how to do the wiring. pleaaseee..
Message 27 of 44
(1,225 Views)
and there are two for loops in the code, the file dialog needs to be placed outside the inner loop or the outer loop.
Message 28 of 44
(1,226 Views)
A couple of things. If you get an error, you need to provide the error number. It does no good at all to just say 'my program doesn't work'. Second, I will repeat my urging that you look at the resources for basic LabVIEW training at http://www.ni.com/academic/lv_training/how_learn_lv.htm.
This is as basic as it gets.
Message Edited by Dennis Knutson on 07-13-2007 11:35 AM
Message 29 of 44
(1,221 Views)
hey dennis
thanks alot for the help with all that stuff. i v been trying to save the user name, sample name and sample description in the saved excel file. could you please guide me how i should do that coz i dont think i am getting too far with it. i have tried to put in 'user prompt' dialogue boxes but i think it is not working. the excel file that gets saved, i want the user to be able to input his name, sample name, and a short sample description.
Message 30 of 44
(1,193 Views)
