how to edit message on discussion forums
Hi
     How to edit one's own messages on discussion forums
Regards
RobinHood
(3,244 Views)
Click on the "option" and select the "Edit message" from the drop down list. see the attached image
Guru
Message Edited by Guruthilak on 03-10-2010 10:34 AM
Regards
Guru (CLA)
(3,240 Views)
Choose Edit Message from the Options menu to the upper right hand corner of your message.  However, you have a time limit.  You can only edit a message up to 10 minutes after you first posted it.
(3,239 Views)
is it 10 or 20 minutes...
Regards
Guru (CLA)
(3,234 Views)
10 minutes
(3,232 Views)
