how to edit xml file particular value. and how to send xml file over ip address 192.168.2.10 using ftp
how to edit xml file particular value. and how to send xml file over ip address 192.168.2.10 device using ftp through Ethernet
(2,898 Views)
Hello
For using FTP function in LabVIEW, I recommend you to check this document: FTP Basics
Also, take a look at FTP Browser.vi, which is available at the Example Finder.
To edit a XML file, try to use VIs in XML palette. Maybe Write to XML.vi helps you.
Post your current VI if possible.
Regards
Mondoni
(2,887 Views)
