I like @Kevin_Price's solution as it is simple and straightforward.
Depending on the size of the arrays, I still think pre-allocation will be the best. Otherwise in a tight loop you will constantly resize the array/memory space which will be slower in all cases. For a small amount of data/iterations I would go with Kevin's solution where memory is not an issue.
