how to enable or disable an Item in run-time shortcut menu
In my VI, I use a table control. and I create a run-time shortcut menu for it. The Items is "Modify" and "Add New". Now I want to disable Item "Add new" some times. So is it possible to get the shortcut menu ref. in order to disable "Add New" Item?
(3,675 Views)
Hi Song,
you get the shortcut menu ref in the "Menu activation" event. With this reference you can use the function "Set Menu Item Info"…
(3,665 Views)
  Is there a way to disable the "right click" short cut menu in the header? I do not want the short cut menu active in the header. I only want the shortcut menu working in the "body" of the table, where the data is located.
Kaspar
(3,405 Views)
