how to figure out if Teststand running sequence using teststand API?
Hi All,
I am developing an application where i need to monitor if teststand is running any sequence currently or not. If it is running i need to put my application in idel mode and once it stops i need to do some functionality like report analysis.
I am trying to use teststand API to try and figure out if any sequence is currently execuiting but not able to.
To get the run state i need to feed in the path of the sequence but that is not an option for me in this application.
(3,193 Views)
Perhaps this is helpful:TSE.png
(3,146 Views)
I get Executions.Count always zero. thanks for the suggestion I was working on something similar but always getting execution count as zero.
(3,132 Views)
