how to fill colour in .gif file which i imported into picture ring
Hello Sir/Madam,
I woluld like to know about the  picture ring
i can import images in it..
but can i fill any colour in (.gif or .png) in it(picture ring image)?
for example :
i send you one attachment which is figure of tanks(A and B) , i want to show
flow of water from A toB  in coloured format .
means i want to fill colour in that pipe so it shows like a flow of water from A to B
how it possible?
 Ashwini Lele
(2,855 Views)
Hi Ashwini Lee,
you can use the tank controls and some customized button to do what you need. Why do you want to use a picture ring?
Hope it helps.
Mike
(2,849 Views)
You can take a look at the Control Mixer Process Demo. Boolean controls can be used to simulate the pipes, as Mike alluded to. Depending on how fancy you need to get you may want to look at the DSC module. I believe it comes with a whole bunch of factory-type controls.
(2,822 Views)
