how to find approximate time stamp from an array of time stamp
Can some one suggest a logic to find out the index from a time stamp array for a specified time stamp constant.
The array may not conatin the exact time with specifed seconds. So it can be near by time value.
(The array of time stamps may have around 10,000 elements)
Thank you.....
(2,812 Views)
Well, it depends on how picky your sorter needs to be. If you know that there will be a timestamp with the same minutes, and you're okay rounding to minutes, then you could do this:
--Ryan S.
(2,802 Views)
Accepted by topic author thirumala
Here's an approach that will find the index with the closest time stamp:
(2,794 Views)
Dear CMal,
Thanks for providing the solution....
(2,748 Views)
Thanks for providing the reply....
(2,746 Views)
