how to find greater among two time/date string
HI All,
if I have two Date/time string  , In that how to find which is greater time and smaller time ?.
How to substract smaller time from greater time and result should be in seconds.
Kinldy suggest me , if anyone tried this.
I calculated the current date/time string  as shown in vi.
Regards
Punith
(3,560 Views)
Convert String to Timestamp and subtract both as you can find in example
(3,549 Views)
LabVIEW timestamps are numeric values, counted in seconds since Jan 1, 1904.
https://www.ni.com/en/support/documentation/supplemental/08/labview-timestamp-overview.html
You can use the LabVIEW comparison functions with timestamps.
To compare two strings that contain date/time information, you will need to convert the strings to numbers.
This can be done in several ways, but I prefer to use the Scan from String function.
Your format string is incorrect. The month and day formatters should be lower case. I can't say I've ever seen anyone use a dash as a separator between hours, minutes and seconds. The typical delimiter is a colon ( : )
I would expect a date time string to look something like 2015-06-08 07:04:45
To scan this as a LabVIEW timestamp, you would use the format string %<%Y-%m-%d %H:%M:%S>T
(3,545 Views)
