how to find inflection points in an array consisting of several lines with different slopes
Please see the following graph. These points is plotted from an array(1D) vs. index. It consists of several strictly straight lines with different slopes. I  wish to find the indexes of those inflection points (red arrows indicated).  Is there any function or method?
(5,083 Views)
Hi weitong,
calculate the slope for each pair of points. When the slope changes you found an inflection point…
(5,061 Views)
If you have completely noiseless data, this is trivial. Where does the data come from?
What have you tried so far?
(5,055 Views)
These data points are generated by user defintion.  They are generated piece by piece, however they are stored in a 1D array without separation.   Sometimes, it is needed to be read back and rewapted into piece by piece from this 1D array for editing.
(5,010 Views)
You could just do two derivatives.  Where the second derivative is not 0 (change in slope), you got an inflection.
(4,981 Views)
