how to find phase angle using labview
Hi all,
        i am doing a project using myRIO. I have given analog inputs and i found out voltage and current of R and RL load. can any one tell me how to find out phase angle between voltage waveform and current waveform using labview. please any one help me.
Message 1 of 8
(8,794 Views)
Hi, you can use extract single tone VI for each signal, then you just substract both phase angles.
http://digital.ni.com/public.nsf/allkb/F4BB644ECCA595D886256FFE00722E29
Message 2 of 8
(8,783 Views)
I tried using Extract signal tone but doesn't work it shows output value as NaN. I have tried different methods for finding phase angle but none worked out. please any one help me figure out this. i have to find phase angle for square wave. please any one help me.
Message 3 of 8
(8,614 Views)
Hi swathik,
generic answer to your generic problem description: attach a VI with some sample data!
Message 4 of 8
(8,592 Views)
I had the same issue, the extract single tone vi didnt work. I then opened the "extract single tone.vi" by double clicking on it and copied and pasted the whole block diagram contents onto my block diagram and it worked. Give this a try and it might also work for you.
Message 5 of 8
(8,485 Views)
That makes no sense at all!
Can you describe what did not work and what you did. (maybe attach the code before/after).
The same code gives in the same result unless something else is going (e.g. race condition, miswire, mistake, etc.)
Message 6 of 8
(8,472 Views)
This also didnt make any sense to me. But thats what made my code work. I tried all the different apporaches using fft and correlation for 2-3 weeks searching on internet , posting on different forums asking different ppl around me. And i just gave this a try and it worked. I dont know how. Smiley Surprised  Smiley Happy
Message 7 of 8
(8,436 Views)
this only worked when the signal was given from the function generator. I haveyet to  figure out to find the phase when the signal is given from mics. Smiley Frustrated
Message 8 of 8
(8,425 Views)
