I'm not sure if you already have the cluster made or not... but an easy way to find and display what is inside, is to right click the cluster icon on the back panel > create > indicator. This will automatically configure the indicator so that it dispalys everything correctly.
Also if you need to see the elements individually, use the unbundle command. Again to create indicators for each element of the unbundle, you can right click > create > indicator, like I have shown in the attached image. This image demonstrates how to create an numeric indicator off of the array size module.
Hope that helps.
