how to find the defference between elements in an array
hi guys,
this is probs an easy one for you but how can you find the diffence between all elements in an array?
e.g array = 1 2 3 4 5 6
so difference between 1 and two is 1, difference between 1 and 3 is 2. all the way to trough to the differece between 6 and x is x etc.
i have been trying to use shift registers but cant quite get it.
Message Edited by adamkse on 09-02-2009 01:18 AM
Message 1 of 18
(7,980 Views)
Try a Rotate 1-D array.  (It's in the array functions).  I think it will do just what you want.  If it doesn't, let me know.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 2 of 18
(7,965 Views)
hope this helps:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 3 of 18
(7,959 Views)
Message Edited by Ravens Fan on 09-01-2009 09:00 PM
Message 4 of 18
(7,957 Views)
You need to clarify your question.
Do you simply want to subtract indexes of  same array or indexes of different array.
I suppose you mean you have an array, and you want to be able to subtract one element from another element of the same array?
If that is the case, you can simply have two controls, and connect them to the index array function.
Message 5 of 18
(7,954 Views)
Thanks for the fast replys guys.
to try and clarify what I am wanting to do: I want to subtract one element from all others then move to the next element then subtract all others, all the way though to the end. This is all within the same array.
Harold's idea was close but only works for the first element.
Message Edited by adamkse on 09-02-2009 02:27 AM
Message 6 of 18
(7,942 Views)
you could replace my constant in the index array with a control and step through the array and it should subtract properly
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 7 of 18
(7,933 Views)
maybe this:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 8 of 18
(7,931 Views)
Accepted by topic author adamkse
No need for the outer loop.
Message Edited by Ravens Fan on 09-01-2009 09:53 PM
Message 9 of 18
(7,928 Views)
or maybe this:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 10 of 18
(7,924 Views)
