how to find the devices connected in the network
Hi all
I need a help from you all
I want to know how to get all the IP address of the hardware systems connected in the network through Labview
I am going to connect around 35 Lantronix XPORT devices to my PC.
I need to communicate with it based on the IP address of the devices
So can anyone help me in resolving this
Is it possible to change the IP address of that devide from Lantronix
Thanks and regards
Bala
(4,058 Views)
Hi Bala,
If you are using a router to connect all the devices, you may be able to get the addresses from the routing table.
Else use something like Angry IPscan utility (search google) to create a text file and then read it in LabVIEW.
Hope that helps
Vikas
(4,054 Views)
Asked the same question here.
(4,040 Views)
