how to find the sequence of VI's that call a common subvi?
I am using LabView 8.5.  I am using a subvi called "Hardware - counter time" . This subvi is used in 5 other subvi's which are part of a main VI.  Currently, there seems to be some bug in setting up the analog data acquisition task which throws the message - " Hardware -counter time vi was read before the task was set". This message window pops up and there is only a 'OK' button; no other information whatsoever on the message window. Since this is not an error message, it is hard to find out from where this error is coming. I tried hard but with no luck.
Here are my questions:
1. When you get a message that complaints about a common subvi that is used in multiple places, how do you find out at which instance of the use of the subvi the message is coming from?
2. Since 5 different VI's use this subvi, I would like to find out the exact sequence of those 5 caller VI's when the main VI is executed.  Is there a way I can do this ? This could help answer the first question.
Any help will be greatly appreciated.
Mani
(2,906 Views)
You can use the call chain VI in the Application Control Pallette.  Append that String into the error message in the case of an error.
(2,904 Views)
Hi masu,
You can open a logfile and let your subvi add an entry everytime it ist called.
Write a timestamp and the call chain data that Raves Fan has described into each entry, so you get a complete history of how your subvi has been used.
If writing to a file is too slow an operation (as you seem to be working with hardware counters ...) you might use a "log.vi" instead, that collects log entries as an array in an uninitialized shift register. Those data can then be looked at or dumped to a file when your application has completed.
I hope this helps
Anke
(2,884 Views)
Hello Ravens Fan and Anke,
Thanks a lot to both of you. You suggestions really helped.
Mani
(2,868 Views)
