I am using LabView 8.5. I am using a subvi called "Hardware - counter time" . This subvi is used in 5 other subvi's which are part of a main VI. Currently, there seems to be some bug in setting up the analog data acquisition task which throws the message - " Hardware -counter time vi was read before the task was set". This message window pops up and there is only a 'OK' button; no other information whatsoever on the message window. Since this is not an error message, it is hard to find out from where this error is coming. I tried hard but with no luck.
Here are my questions:
1. When you get a message that complaints about a common subvi that is used in multiple places, how do you find out at which instance of the use of the subvi the message is coming from?
2. Since 5 different VI's use this subvi, I would like to find out the exact sequence of those 5 caller VI's when the main VI is executed. Is there a way I can do this ? This could help answer the first question.
Any help will be greatly appreciated.
Mani
