06-17-2015 02:08 PM
Hello all,
Is there a way to progromatically get the channels set thermocouple type? I ask becasue i want to write the thermocouple type in my tdms log. I assume if possible it is a property node function, but i cant find it.
Thanks for any advice.
Solved! Go to Solution.
06-17-2015 03:30 PM
The property node you are looking for is the Analog Input:Temperature:Thermocouple:Type in the DAQmx Channel Property Node. If you cannot find it, it may be because it is a Device-specific property, thus you should configure the filter setting of the property node to show all attributes or select your specific device which supports a thermocouple input
06-17-2015 03:43 PM
When you write this to your TDMS file be sure and write it as a property of the channel you are logging, you don't need to log it as a new channel. Basically values that don't change, and are a single value should be a property, things that have multiple samples should be a channel. I've seen too many people try to write properties as channels and end up with huge files that Diadem can't do much with.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
06-17-2015 04:17 PM
Thank you for the advice and hooovaahh im working on that portion of the code.
If you i have different thermocoupl types in the same task how would i get the thermocouple type for each one?
06-17-2015 07:32 PM
