how to find winddraw sub vi
i have labveiw 7 and i have installed IMAQ 2.5.7 and found some IMAQ samples and trying to run and see what it does but some files like Winddraw sub vi or Windclose sub VI are missing i would like to see where i could find those sub vi's
thanks
(2,399 Views)
Hi Leonitas,
Thank you for posting on the National Instruments discussion forums.
I have installed LabVIEW 7.0 on a test machine and attempted to install the NI-IMAQ 2.5 drivers, but these don't appear to be compatible with LabVIEW 7.0, so this may be the issue.  I did find that the NI-IMAQ 2.6 drivers are compatible with LabVIEW 7.0, so I would suggest you install these.  They are available to download here:
http://joule.ni.com/nidu/cds/view/p/id/766/lang/en
Please give these a try and post a reply if they do not resolve the issue.  Thanks.
Rishee B.
(2,362 Views)
